Activity Forums VEGAS Pro Adding motion to still pictures gives flickering effect
  • Adding motion to still pictures gives flickering effect
    Posted by Lodge7490 on September 25, 2007 at 6:06 pm
    Hi, I use Vegas to animate still pictures of houses (interior/exterior) to create virtual open houses. I add brightness and contrast filter if needed and light sharpening filter on every still. I add motion to every pic to simulate movement. But when I render some of the animations have flickering/studdering lines. I mostly see these lines like on the roofs of houses (shingles etc.) and on trees (leaves etc.). I’ve tried all the rendering options (None progressive scan, lower field first, upper field first) and still get that flickering effect. I’ve used a filter on Final Cut Pro called de-interlace (flicker filter max) to get rid and clear most of the flickering lines and it works fine, but I need a similar solution for Vegas. Any ideas?
    David Shirey replied 18 years, 11 months ago 3 Members · 2 Replies
  • John Gordon
    September 25, 2007 at 8:17 pm
    right click on the event, select the reduce interlace flicker or you could add a slight gaussian blur of .001 to the pic to help conceal the “jitters”. It’s a common occurance in high resolution pictures.
    Good Luck
    John
  • David Shirey
    September 27, 2007 at 8:17 pm
    Sometimes if that doesn’t help it enough, I just resize the photos real quick. I mainly work in SD so 3000xwhatever jpgs are overkill for 720×480 video. You can shrink them in any image program without losing the motions you’ve already done in Vegas.
