Activity › Forums › Adobe Premiere Pro › Adding Motion Blur to Stills or Titles
  • Adding Motion Blur to Stills or Titles
    Posted by Vincent Rosati on June 30, 2012 at 11:45 pm
    In older versions of PP I could add Video Effect / Distort / Transform to a title or still image, then I could set the motion keyframes, select ‘Use Composition’, select ‘Motion Blur’, and set the ‘Shutter Angle’ to whatever value to get an appropriate blur for the motion.
    In PP CS4, Motion Blur no longer appears to be available in the Transform filter.
    Question 1
    How do I add motion blur to titles or stills, based on either the Motion parameter or the Position or Anchor Parameter in the Transform filter?
    Or, is there a newer better way to achieve this?
    Question 2
    What is Shutter Angle for, in the Transform filter, if there is no option for Motion Blur?
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
    Ann Bens replied 14 years, 3 months ago 2 Members · 1 Reply
  • Ann Bens
    July 2, 2012 at 7:27 pm
    I think you have to turn to AE for this effect.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
