Activity Forums Maxon Cinema 4D Adding More Ram To Cinema 4D?
  • Adding More Ram To Cinema 4D?
    Posted by Brandon Kliss on July 6, 2011 at 10:15 pm
    I’m running on a mac these are my specs:
    Model Name: MacBook Pro
    Model Identifier: MacBookPro6,1
    Processor Name: Intel Core i7
    Processor Speed: 2.66 GHz
    Number Of Processors: 1
    Total Number Of Cores: 2
    L2 Cache (per core): 256 KB
    L3 Cache: 4 MB
    Memory: 8 GB
    When i render I only have 4 of my ram rendering, but i have another 4 that cine isnt using, how can i make cinema 4D render with all of my ram?
    Luke Wheldon replied 13 years, 8 months ago 4 Members · 5 Replies
  • Adam Trachtenberg
    July 6, 2011 at 10:21 pm
    Sounds like you aren’t using a full 64 bit OS, or you’re not using the 64 bit version of Cinema. I’m a PC guy so I can’t be more specific than that….
  • Nolan Scott
    July 7, 2011 at 12:32 am
    Your MacBook Pro should be able to run in 64-bit Kernel Extensions…
    Open the System Profiler / select Software / 64-bit Kernel Extensions might say No ?
    To switch into 64 bit / Restart and hold down the 6 and 4 keys until you see the apple logo.
    Check System Profiler again / 64-bit Kernel Extensions should say Yes ?
    Next time you restart without holding down the 6 and 4 keys you’ll be back in 32-bit…
    In your Application folder select the Cinema 4D.app / Get Info.
    Make sure that open in 32-bit mode is unchecked.
    Regards
    Nolan
  • Brandon Kliss
    July 7, 2011 at 1:17 am
    THANKS! THAT WAS IT!
  • Luke Wheldon
    January 19, 2013 at 3:03 pm
    Sorry to be a pain. I know this was posted years ago but what do you mean by “system profiler”?
    Luke.
  • Luke Wheldon
    January 19, 2013 at 3:12 pm
    Hey, Ignore that. I was being dumb! Still can’t get it to use more RAM :/
    Luke.
