Activity › Forums › Adobe After Effects › Adding more memory
Adding more memory
Posted by Jerel Peterson on June 16, 2014 at 12:19 amI’ve always read that adding more memory will speed up AE. But is that just for RAM PREVIEWS, or does it also speed up the final rendering?
John Cuevas replied 12 years, 2 months ago 2 Members · 2 Replies -
John Cuevas
June 16, 2014 at 11:35 amIt can speed up final rendering, in multiple ways. Check this out: Improve performance
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
John Cuevas
June 16, 2014 at 12:53 pmThe big one, when rendering more RAM allows for more multi-processing. Which if you combine that with a large SSD drive for disk cache, AE will be able to pull those pre-rendered frames quickly into your final render.
