[Lexi Elven] “Is there a way to add more detail in to my parameters so I’m not working with ridiculously small increments?”
Not directly. I don’t know enough about your project to suggest a better workflow, but here are a couple ideas.
Hold Command on a Mac, or Control on Windows, while scrubbing a parameter to make fine adjustments.
Alternately, you could add a Slider Control effect to your footage, then link your parameter to it. Throw in a little math to make it more responsive. For example, to animate Position, you could add two slider controls and rename them “Position X” and “Position Y.” For the position parameter on your solid, add an expression:
x = effect("Position X")("Slider") / 10;
y = effect("Position Y")("Slider") / 10;
[x, y]
A move of 10 on Position X will now correspond with 1 pixel on your comp. Change the value in the expression to make it more or less responsive.
Walter Soyka
