Activity Forums Apple Final Cut Pro Legacy adding more columns??
  • adding more columns??
    Posted by Rob Davis on August 30, 2005 at 11:24 pm
    Hi, about to migrate from Avid to FCP5. However our logging info has many user definable columns. I see that 6 seems to be the max columns that can be modified. Is this the limit?
    thanks in advance
    David Bogie replied 21 years ago 2 Members · 1 Reply
  • David Bogie
    August 31, 2005 at 9:19 pm
    I don’t even know, sorry. I’ve never used user-defined columns in ten years of NLE.
    You’re not going to like migrating to FCP.
    Suggest you obtain one of the “FCP for Avid Users” books before you commit. The move may not be worth doing till you’ve gotten your current inventory of projects out the door.
    There are thousands of disaffected and Avid users and they’ve become happy FCP users. But there are thousands of folks who just cannot tolerate this kind of change. It’s a different app. Doesn’t do stuff the same way, doesn’t work the same way, doesn’t handle its job the same way. Everything is abruptly weird.
    bogiesan
