Activity Forums Apple Final Cut Pro Legacy adding monitors and projectors
  • adding monitors and projectors
    Posted by Jasmine1919 on October 23, 2006 at 12:03 pm
    Hello,
    I am using a new Mac Pro 5 tower with two screens and would like to be able to have my canvas through my Panasonic projector as well as another monitor to see the qualioty of the footage. What do I have to do? I have an installed blackmagic deckling and think i should be able to at least hook this one through BNC cables to the projector, but will it work automatically as a third screen? and what if I want to ad yet another TV monitor? Do I need a second graphic card for all this? What is the most logical way to set this up?
    Thank you soo much for your advices
    Jasmine
    Zak Mussig replied 19 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Bouncing Account needs new email address
    October 23, 2006 at 12:17 pm
    If the monitor you have has a “looping” output… there will be video “INPUT” jack(s) and video “OUTPUT” jack(s)… then just hook that output to the projector.
    If not, you need a DA (distribution amplifier) with one video input and multiple video outputs in the type (component, composite, or S-video) that you want to use.
  • Walter Biscardi
    October 23, 2006 at 12:45 pm
    [Jasmine1919] “I am using a new Mac Pro 5 tower with two screens and would like to be able to have my canvas through my Panasonic projector as well as another monitor to see the qualioty of the footage.”
    I’m assuming you mean you want to project your NTSC footage from the Canvas, NOT the actual FCP Canvas from the interface. If you mean trying to make the Canvas in the FCP interface larger, you will not get a sharp image and have no idea what the actual quality of your footage is. FCP degrades the image in the Viewer / Canvas because you are expected to view your footage externally, such as through the Decklink card.
    You want to hook the Decklink to your projector / monitor and then set up FCP to display actual video through the card, not the FCP interface.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Jasmine1919
    October 23, 2006 at 3:36 pm
    thank you guys,
    Walter could you please give me a hint on how to set my FCP for the footage to be shown through the projector?
    thank you
    October 23, 2006 at 4:02 pm
    What kind of projector?
    What do you project with it now?
  • Jasmine1919
    October 23, 2006 at 4:32 pm
    I use it for TV and it is a panasonic PTE AEA900E, high def…
  • Jasmine1919
    October 23, 2006 at 4:36 pm
    and it is hppked on a vhs/dvd machine so sole scart and HDMI in are in use. Leaving us with the serial, a 15pin PC in, an S-vid and component in blue red and green
  • Jasmine1919
    October 23, 2006 at 4:37 pm
    and it is hppked on a vhs/dvd machine so sole scart and HDMI in are in use. Leaving us with the serial, a 15pin PC in, an S-vid and component in blue red and green.
  • Zak Mussig
    October 23, 2006 at 5:03 pm
    Assuming that you DeckLink card is one of the models with analog in/out and is HD capable, hook the Component (RGB) OUT from the card to the Component IN on the projector. Then just set the projector to the component input.
    Zak
