Activity Forums Maxon Cinema 4D Adding Materials to a Extruded Nurb
  • Adding Materials to a Extruded Nurb
    Posted by Durwood Hibbard on October 10, 2013 at 2:33 am
    Good Day,
    I hope I can make this understandable enough for someone to help out.
    I have a 2d image that I have preformed a live trace on in Adobe Illustrator. I have saved it and opened the file in Cinema 4d. When it opens any color information that was there is gone leaving only the wireframe to look at.
    I am taking the paths of my image and combining them by selecting them all then right clicking and selecting connect+delete. Then I am preforming an Extrude Nurbs while holding alt+command.
    To this point everything looks ok, however, when I try to add materials (just using simple colors) it will not allow me to add them to the image/object. The cursor is the red circle with the slash across it.
    I have tried to add the materials prior to extruding also with the same results.
    What am I missing? Please Help. Thank You.
    Durwood Hibbard replied 12 years, 11 months ago 2 Members · 2 Replies
  • Thomas Pascavage
    October 10, 2013 at 3:21 pm
    convert it to a polygon object if you don’t need to animate it and check your normals
  • Durwood Hibbard
    October 10, 2013 at 11:08 pm
    I would like to have the camera pass by it, but I am not looking to animate it, itself. Will having a camera movement cause a problem?
