Activity Forums VEGAS Pro adding masks slows playback to a halt
  • adding masks slows playback to a halt
    Posted by Mike Owens on February 26, 2010 at 8:37 pm
    Using Vegas Pro 9. I’m adding lightsaber and laser blaster by rotoscoping masks over about 20 seconds of footage. When completed, if I try to play the movie, the audio plays fine but the video will barely display one frame every 5 seconds.
    I don’t have this problem on similar length footage where I’ve used a chromakey or other fx plugins.
    I use NeoScene proxy files for all HD footage, which has traditionally kept realtime editing and playback on my new Windows 7 workstation (10,000 rpm drives, 8mg RAM, Nehalem i7 processor, etc.)
    MO
    Terry Esslinger replied 16 years, 6 months ago 3 Members · 3 Replies
  • Theo Van laar
    February 26, 2010 at 8:46 pm
    Did you try the RAM preview already? Or the RENDER TO NEW RACK (Ctrl M)? The last one I like most…
    Theo
  • Mike Owens
    February 27, 2010 at 12:34 am
    Thanks! The prerender was exactly what I needed.
  • Terry Esslinger
    February 27, 2010 at 2:08 am
    Are you using particle illusion for light saber and blaster effects? If NOT can you explain how you are doing them?
