Activity › Forums › Apple Final Cut Pro Legacy › Adding mask and increasing the scale.
Posted by Robinson on December 14, 2006 at 5:36 amHi,
I need to add a slow zoom out on the picture which I am doing by scaling down the size between the two keyframes. However that affects the widescreen mask/or any other mask that I am using on the image to get the true anamorphic composition.
What’s the way around it? any other effect I can use???
Thanks in advance for the help.
Jeremy Garchow replied 19 years, 9 months ago 4 Members · 7 Replies -
Arnie Schlissel
December 14, 2006 at 6:29 amSimplest way is to place a slug on a layer over your picture & use a garbage matte to cut a hole in it to reveal the picture beneath.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Jeremy Garchow
December 14, 2006 at 6:38 amYou could nest the clip, adjust the clip in the nest, then put the windscreen matte on the nest itself.
You could make a still image of the mask in photoshop with an alpha and position your footage under it.
Buy Nattress Film effects and use his widescreen filter
https://www.nattress.com/Products/filmeffects/G_Film_Matte.htm
Jeremy
Jeremy Garchow
December 14, 2006 at 6:50 am[JeremyG] “windscreen”
Damn Apple spell check, why hath you forsaken me?
That’d be wide screen, not wind screen.
Arnie Schlissel
December 14, 2006 at 7:07 am[JeremyG] “Damn Apple spell check”
Thing is, you spelled windscreen correctly. How’s the spell checker supposed to know that you’re not riding in a car?
Arnie
David Smith
December 14, 2006 at 2:42 pmdarn, I thought that was the special filter for removing the blimp a sound recordist dips into the shot.
Jeremy Garchow
December 14, 2006 at 4:16 pmExcellent point Arnie, but in this case, I totally blew the spelling altogether and Apple corrected it with windscreen. Henceforth, I hath been forsaken. Yarggggg! More accurately, I hath forsaken myself in a total self destructive spelling plight and doing so rightfully confused the Apple spell checker into thinking I was talking about another piece of totally unrelated production gear.
Weird.
