Activity › Forums › Adobe Premiere Pro › Adding MArker on the timeline or in the source panel
  • Adding MArker on the timeline or in the source panel
    Posted by Mark Pirres on March 11, 2014 at 11:34 am
    Hello
    Question about adding markers to either the timeline or in the source panel: I have read on a tutorial that pressing Alt/option and clicking on the marker, it will split the marker into two, which will allow to stretch its length for the duration needed. I have tried and tried this, but it doesn’t work. The only way I can get the marker to “stretch” is going in the Markers window and change the out point, but that’s a bit of a drag… Does any one know another way to split the marker?
    Mark Pirres replied 12 years, 6 months ago 2 Members · 4 Replies
  • Kevin Monahan
    March 11, 2014 at 10:38 pm
    Hi Mark,
    Which version of Premiere Pro are you using? This is a Premiere Pro CC feature and won’t work with Premiere Pro CS6.
    Hope that helps.
    Kevin
    Kevin Monahan
    Online/Social Customer Success Lead DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Mark Pirres
    March 11, 2014 at 11:25 pm
    I’m sure the tutorial I’ve watched was saying CS6 – which is what I’m using – but they must have got it wrong.. Shame then..
    Thanks anyway!
  • Kevin Monahan
    March 12, 2014 at 7:48 pm
    Can you point me to the tutorial?
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
  • Mark Pirres
    March 13, 2014 at 10:30 am
    Hi, I’ve double checked and I got it wrong, sorry! I had googled premiere pro CS6 and somehow remembered the tutorial referring to CS6 instead of CC..
