Activity › Forums › Adobe Premiere Pro › Adding Log Notes during Scene Detect Capture
  • Adding Log Notes during Scene Detect Capture
    Posted by William Mcqueen on October 19, 2005 at 7:32 pm
    In the process of capturing footage from tape, PP1.5 offers an opportunity to place a log note. However, when using Scene Detect, how can you add the Log Note either contemporaniously, or after the capture?
    So, say I end up with 50 clips on my hard drive. How can I add descriptive log notes that will appear in the Project file?
    Thanks for your collective wisdom.
    Cheers,
    Bill in Toronto
    William Mcqueen replied 20 years, 11 months ago 2 Members · 4 Replies
  • Craig Howard
    October 19, 2005 at 8:04 pm
    I type comments etc in, once the clips are in the Project bins.
    I also take the opportunity to delete unwanted captured clips from the project and teh drive at the same time.
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • William Mcqueen
    October 19, 2005 at 8:46 pm
    Can you describe how you type in the Log Comments after the clips are in the bin, I don’t know how to do that.
    Bill in Toronto
  • Craig Howard
    October 20, 2005 at 12:23 am
    I literally type into the columns besides each clip in the Project Window. (It is then saved with the project)
    Often I customise the columns for each project using the Edit Columns feature. Wish I could make a Default set up for this tho’.
    Craig
    Auckland
    New Zealand
  • William Mcqueen
    October 20, 2005 at 5:17 pm
    Thanks so much, Craig.
