Activity › Forums › Adobe After Effects › Adding light causes crash
Posted by Kris Sheehan on June 30, 2016 at 1:51 pmI am running into an issue where in any project if I add a light and start to move it around AE locks up and can’t recover. Not sure if this a problem in the 2015.3 update or if there is something I am missing. I’ve opend a new project and start from scratch and still run into the same problem. I reinstalled AE and still have the same issue. My project is due tomorrow and I am at a total loss for how to get around this. Anyone with the same problem/did you find a work-around?
Michael Szalapski replied 10 years, 1 month ago 5 Members · 7 Replies -
Walter Soyka
June 30, 2016 at 1:59 pmI have no trouble creating or moving lights in Ae 2015.3, in either Classic 3D or ray-tracing comps.
What are your Fast Preview settings (the lighting bolt under the comp viewer panel)? Does it make a difference if you change them?
Have you tried resetting your preferences? Re-installing does not automatically reset preferences.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Ash Curkpatrick
July 6, 2016 at 7:48 amI’m having the same issue. Specifically it has to do with adding a Spot Light. Ambient Lights work fine.
I am running After Effects CC 2015.3 on Windows 10
Michael Szalapski
July 9, 2016 at 1:42 pmI can re-produce this problem if I make my spot light have a cone angle of 180 degrees. It crashes regardless of fast preview settings or hardware accelerate settings. It was fine with a different angle, but 180 killed it.
So, file a bug report with Adobe and then make your spotlight with a different cone angle.
– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Michael Szalapski
July 9, 2016 at 1:44 pmSide note: I did not have this issue on my Mac.
– The Great Szalam
Michael Szalapski
July 9, 2016 at 2:29 pmDoes my experience match yours? Can you create a spot light with a smaller cone angle (like 120?) or does it crash for you regardless?
– The Great Szalam
Fletcher Mcdonald
August 7, 2016 at 7:17 amThis is also happening to me. Whenever the camera loses sight of the light (or gets too close) AE freezes immediately and only a Ctrl+Z works after a few seconds of waiting.
Michael Szalapski
August 7, 2016 at 6:27 pmHave you tried in the CC 2015.3.1 update (AE version 13.8.1)?
– The Great Szalam
