Activity Forums Creative Community Conversations Adding larger clip to smaller timeline
  • Adding larger clip to smaller timeline
    Posted by Bryan Mullennix on November 18, 2013 at 6:22 pm
    Hi all,
    I’m having a problem where when I add a larger clip (3861×2574) to a smaller project (3840×2160) the clip is shrunk to fit completely within the projects properties. At this point the scale in the transform section says it’s at 100%. When I use transform to scale up the clip I have to go to about 120% to fill the frame and the resulting image quality is degraded.
    When I’m adding a larger clip to a smaller project shouldn’t I have to scale it down to fit rather than up? Is there a way to add this clip to the timeline without it being automatically scaled down? I would expect when adding the clip that even if it was scaled to fit entirely within the project parameters that the scale % in transform section would read 80% or thereabouts and I could scale back up to 100% to fill the frame.
    Thanks for your help!
    Stephen Underwood replied 12 years, 10 months ago 3 Members · 3 Replies
  • Ronny Courtens
    November 18, 2013 at 7:01 pm
    Select the clip and in the Inspector > Video tab set Spatial Conform to None. Now your clip will not be downscaled to match the Project frame size.
    – Ronny
  • Bryan Mullennix
    November 18, 2013 at 7:04 pm
    Aahh that’s it! Simple solution that I did not know about. Thank you so much!
  • Stephen Underwood
    November 20, 2013 at 5:29 pm
    Thanks for the ‘spatial conform’ tip. Another question…
    I have a 1920×1080 timeline (created by dragging a 5D clip) that I then dragged GoPro 1920×1440 clips into. I then “Crop>KenBurns” to position them vertically, cropping off parts of top or bottom of clip or panning up/dn w/Burns effect. Is that the best workflow to retain highest quality of the GoPro clips?
    And another… In creating a new “GoPro Only” timeline by dragging in a 1920×1440 clip (but wanted to crop all clips vertically to end up with a 1920x1080p movie, what’s the correct method in that case?
    I’d appreciate any advice… Thanks!
    ~ Steve Underwood
    Computer: iMac 27″, (Mid 2011), OS X 10.7.5
    Processor: 3.4GHz, Intel Core i7, Memory: 24GB
    AMD Radeon HD 697OM, FCX 10.08, FCP 7.03
    Pegasus 4TB RAID
    Computer: MacBookPro (Mid 2009), OS X 10.7.5
    Processor: 3.06 GHz Intel Core2Duo, Memory: 4 GB
    Graphics: NVIDIA GeForce 9400M 256 MB, Software: FCX 10.08, FCP 7.03
