Activity Forums VEGAS Pro Adding label to track ?
  • Adding label to track ?
    Posted by Rick Hughes on November 6, 2015 at 2:00 pm
    Using Sony Movie Studio 12
    On a video I may add several individual pieces of music on a single track ..(as apart to separate audio tracks)
    As there may be a number of files in the ‘project media’ window it can sometimes get difficult to know which I have used.
    Is there a way to add a label onto a track .. i.e. give it a name.
    As an example … could have a 15 min video track and I have 5 separate mp3 files …. as I put all these on the same audio track … easier to visualise envelopes, fade in etc. Be good to be able to apply a label to each of the files where they appear in the timeline.
    Seems so obvious I guessing you can, would assume if you right click and event you could add a name – but not so ,,, can it be done ?
    Or even add automatically the name from the media file if that is an option.
    I know if I used separate tracks I can name each track.
    David Eon replied 9 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • Mike Kujbida
    November 6, 2015 at 2:04 pm
    View – Active Take Information.
    Ctrl + shift + I is the keyboard shortcut.
    This is in Vegas Pro so I’m not sure if you have it in Movie Studio. It’s worth a try 🙂
  • George Dean
    November 6, 2015 at 2:59 pm
    It’s exactly the same in Movie Studio 13.
    Best Regards…..George
  • Rick Hughes
    November 6, 2015 at 4:05 pm
    Yes it is …. thought it was so obvious a function.
  • Mike Kujbida
    November 6, 2015 at 8:37 pm
    So was that a solution for you?
  • Rick Hughes
    November 6, 2015 at 9:02 pm
    Mike … when I replied “Yes it is …. thought it was so obvious a function.”
    I meant that in repose to your answer … seems to have arrived out of sequence … it worked Thank you
  • Mike Kujbida
    November 6, 2015 at 9:20 pm
    Rick, I’m glad to hear that it worked for you. I have it enabled all the time.
  • Peyton Todd
    June 12, 2017 at 6:24 pm
    Yes, but how do you turn on the labels that usually (in my case) appear to the left of each track – the ones where you can mute a give track, for example? I never want these to go away, but sometimes they do… I suppose I must have inadvertently pressed some keystroke combination.
  • David Eon
    July 15, 2017 at 8:50 am
    A quick way to match up events on your timeline to the files in the media manager is to select the events you want, then right click>Select in Project Media list. It will highlight all of the source media files that you have selected on your timeline. I hope that helps. Thanks!
    DavidEon
