Activity Forums Adobe After Effects adding keyframes
  • adding keyframes
    Posted by Robert Neuman on July 12, 2010 at 4:39 pm
    How can I add a keyfram between two existing keyframes so that the new keyframe’s attributes is an average of the existing two. For example if there are two Scale keframes, the first set to 0 and the second set to 100, how can I add a third keyframe between the two so it atomatically has a Sacle of 50 (or another number depending on where the new keyframe is placed). Any idea?
    thanks in advance
    Robert
    Chris Tarroza replied 16 years, 1 month ago 3 Members · 2 Replies
  • Bob Root
    July 12, 2010 at 7:13 pm
    There’s a little diamond between the previous and next keyframe buttons (to the far left of your layer properties in the timeline).
    Just click on it to create keyframes at your current position in the timeline.
    You’ll need to have at least one keyframe on your layer property in order to see the add keyframe button.
  • Chris Tarroza
    July 14, 2010 at 7:24 pm
    If you have already created keyframes, changing a setting will automatically create a new keyframe.
    Place the timeline indicator where you want the new keyframe to be. Then change the property that you want and a new keyframe will automatically be created where your indicator is.
