Activity › Forums › Apple Final Cut Pro Legacy › Adding Keyframes to Audio
Posted by Ryan Atkins on June 17, 2008 at 6:14 pmHow do you add keyframes to audio on your timeline for fading it in and out? I’m working with Final Cut Pro 6.
Amy Bower replied 13 years ago 4 Members · 4 Replies -
Jerry Hofmann
June 17, 2008 at 8:49 pmTurn on the clip overlays in the lower left corner of the timeline window. Looks like a line graph. Then use the pen tool in the line that will appear in the audio clips in your sequence… raise and lower accordingly.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
Ryan Atkins
June 17, 2008 at 10:59 pmThank you very much, I found it and it works perfectly – the way I want it to.
Amy Bower
September 5, 2013 at 6:48 pmI have used the pen tool to do exactly this, but for some reason I am unable to get it to work right now. I know this is an easy problem to fix, but I have no idea how to fix it. Sorry for asking such a beginner question, but apparently I am out of practice on FCP. Can you please offer help? Thank you.
