Activity › Forums › Apple Final Cut Pro Legacy › Adding keyframes at the end of clips – can’t see what i’m doing.
  • Adding keyframes at the end of clips – can’t see what i’m doing.
    Posted by Olly Lawer on May 10, 2011 at 3:54 pm
    This has also bugged me for a long time. It’s obviously my day for trying to solve annoying things.
    When I add keyframes to a clip in FCP, I can see on the Canvass the adjustments I make on the Viewer. With one exception. If I want to add a keyframe to the last frame in the clip, I press the down arrow key, which takes me to the next clip – then click back one and double click the clip I was working on in the timeline.
    There must be an easier way?
    Olly Lawer
    Olly Lawer replied 15 years, 4 months ago 2 Members · 2 Replies
  • Chris Morlang
    May 10, 2011 at 5:15 pm
    Double click the clip you want to edit and hit Shift+O to take you to the out point
    ~Chris Morlang~
  • Olly Lawer
    May 10, 2011 at 5:29 pm
    Thank you!
    Olly Lawer
