Activity › Forums › Apple Motion › adding keyframes
  • adding keyframes
    Posted by Roy Schneider on October 2, 2005 at 12:51 pm
    Hi All:
    I have what I think is a simple issue that is driving me nuts. I have a 10 layer project that I have laid out is there a way to manually add a keyframe to all ten layers at once. It will be the same as the last keyframe to stop motion for 15 frames before next move.
    Thanks for your help.
    Roy
    Jim Kanter replied 20 years, 12 months ago 2 Members · 1 Reply
  • Jim Kanter
    October 2, 2005 at 11:50 pm
    1. Select all the layers.
    2. Move to the frame where you want to set an identical keyframe value (to hold the value)
    3. Make sure the Autorecord button is active (glowing red)
    4. Nudge the selected layers up and back (cmd-shift-up arrow, cmd-shift-down arrow).
    This will set a keyframe for the selected layers. This method is for changing the position of the layers but can also be used for other attributes as well.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
