Activity › Forums › Blackmagic Design › adding Intensity card with Decklink SP?
  • adding Intensity card with Decklink SP?
    Posted by J. Tad newberry on July 14, 2007 at 6:34 pm
    i edit with FCPC on Mac G5, and currently have a Decklink SP card for my Betacam deck, and need to be able to capture in DVCPro HD via firewire from and HDV camcorder (yes, trying to uprez HDV on the capture). i hear that the Intensity card (Pro or non-Pro?) will do the trick.
    question: can i just add the Intensity card to another slot and leave my Decklink SP card in place, or will there be a conflict?
    Kristian Lam replied 19 years, 2 months ago 2 Members · 1 Reply
  • Kristian Lam
    July 16, 2007 at 11:17 pm
    You can only use one card per system unless you’ve written your own application. Final Cut Pro will get confused as to which card to use.
    regards
    Kristian Lam
    Blackmagic Design
