Activity Forums Apple Motion adding images and video to a moving board held by talent
  • adding images and video to a moving board held by talent
    Posted by Martyn Greswolde on December 21, 2010 at 12:08 pm
    Hi all,
    As part of a quote I have been asked to return I have been asked to add still images and moving video to a blank board held by the talent in front of them.
    The board will be flipped and moved forwards and backwards by the talent. The images/video will change when the board is flipped. I will need to add perspective adjustments to the images/video to look as if it is pasted to the board.
    I need to know a rough estimate how long this would take a novice to complete in motion, also if you can give me some idea of the complexity of this task that would be great.
    Many thanks
    M
    Greswolde Photography
    http://www.greswolde.com
    I know little but I learn quickly!
    Stephen Smith replied 15 years, 8 months ago 3 Members · 4 Replies
  • Stephen Smith
    December 21, 2010 at 4:58 pm
    Motion has a 4pt tracker that can track the card very well is you see all 4pts. The hands will be holding the card and you will need to key or mask the hands so they don’t get lost in front of the card. I would recommend you do a quick test to see how comfortable you feel with this. Hope this helps and best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Martyn Greswolde
    December 21, 2010 at 5:20 pm
    Thanks for the reply Stephen.
    The board will actually go off the screen edges at times so If we were to used a board like this – https://grab.by/80Bg I could use the crosses to track from and place the overlaid image up to the blue border?
    Will the tracker completely distort the image to nothing as the board is flipped horizontally?
    Cheers
    M
  • Mark Spencer
    December 21, 2010 at 5:30 pm
    This is going to be quite difficult to pull off with Motion’s tracker especially if you’ve never done tracking before. I’d highly recommend you do a test first – and if you can’t make it work, try Mocha from Imagineer.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Stephen Smith
    December 21, 2010 at 5:32 pm
    I agree, Mocha will most likely be the way to go.
    Stephen Smith
