Activity › Forums › Compression Techniques › Adding image sequence to OpenEXR ?
  • Daniel Low
    October 25, 2009 at 6:43 pm
    Yes.
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today: 30 April 2007
    “We and Apple are neck and neck and we’re chasing the two
    other players,”
    Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
  • Christopher Rotter
    October 26, 2009 at 2:11 am
    Yes ? How ?
  • Daniel Low
    October 26, 2009 at 10:10 am
    Certain 3D animation packages including 3DS Max and Blender can perform this.
    other players,”
    October 26, 2009 at 2:32 pm
    What I mean is if you have already a OpenEXR file format, and you want to add a image sequence into the existing OpenEXR file format !
  • Daniel Low
    October 26, 2009 at 10:20 pm
    [Christopher Rotter] “What I mean is if you have already a OpenEXR file format, and you want to add a image sequence into the existing OpenEXR file format”
    I don’t quite understand. Do you mean you have an OpenEXR image sequence and you want to add to it? Or that you want to create an OpenEXR image sequence with some OpenEXR images?
    other players,”
    October 26, 2009 at 11:32 pm
    That is exactly what I mean 🙂
  • Daniel Low
    October 26, 2009 at 11:50 pm
    Any use?
    https://www.fnordware.com/OpenEXR/
    other players,”
    October 27, 2009 at 1:33 am
    Correct me if I’m wrong. With this plug-in I can take a sequence of images and add them to an existing OpenEXR file ? If I’m right I’m trying read where it does this 🙂
  • Daniel Low
    October 27, 2009 at 9:57 am
    [Christopher Rotter] “Correct me if I’m wrong. With this plug-in I can take a sequence of images and add them to an existing OpenEXR file”
    I have no direct experience with the plug-ins but it would appear that the they enable you to work with OpenEXR images and sequences from within AfterEffects.
    other players,”
