Activity Forums Maxon Cinema 4D Adding Gravity in C4D LITE
  • Adding Gravity in C4D LITE
    Posted by Chelsea Deak on February 20, 2018 at 4:50 pm
    I’m working on a project where an object falls from above and is supposed to hit the ground and leave an indent/crack. But I’m using the Lite version of C4D.. Is there any way to drop an object with gravity in the lite version without using the collision and dynamic tags? as you do not have that option in the lite version..
    Justin Thomson replied 8 years, 6 months ago 2 Members · 1 Reply
  • Justin Thomson
    February 20, 2018 at 5:14 pm
    if it’s one object you could just animate it with keyframes.
