Activity Forums VEGAS Pro Adding graph – Sony Vegas
  • Adding graph – Sony Vegas
    Posted by Tomasz Tomkiewicz on August 23, 2015 at 12:40 pm
    I’m looking for some way to add graph to movie using Sony Vegas. I want to do something like this (I haven’t found another video with that “effect”) https://www.youtube.com/watch?v=tkB8gpPzMkw
    Is it possible to do this using Sony Vegas?
    BR, Tom.
    Bob Peterson replied 11 years ago 2 Members · 1 Reply
  • Bob Peterson
    August 23, 2015 at 5:35 pm
    You could create the graph in something like Photoshop. If you want the curves to be progressive on the timeline, they will need to be created separately. Then, you can reveal the curves in one of two way. You can set up a mask to slowly reveal the curves, or you can pan across a wide graph. Either way, use pan/crop with key frames.
