Activity Forums Apple Final Cut Pro Legacy Adding Grain Using Composite Mode – overlay confusion
  • Adding Grain Using Composite Mode – overlay confusion
    Posted by Andrew Smith on December 20, 2011 at 3:31 am
    I am trying to add grain to my 1080 ProRes444 rendered 15 minute short film: It is originating from R3D footage I graded in Resolve – conformed from an xml offline edit but the look they want is gritty not so sharp.
    I am a bit confused about how to use my AE render of grain with fcp’s overlay mode so maybe i am doing something wrong in AE or FCP because when i try overlay or any other mode its not just showing the grain its actually effecting the shot overall making it darker etc but not what I want – must be doing something wrong here guys.
    I have provided some screen grabs of my settings in AE just in case its a setting in there but if not and I am just not fully understanding in FCP how to adjust with contrast etc PLEASE feel free to break it down and explain.
    Andrew Smith replied 14 years, 8 months ago 3 Members · 10 Replies
  • 10 Replies
  • Bret Williams
    December 20, 2011 at 7:25 am
    Drop the grain in FCP over the clip. Then right click on the grain clip and try the composite modes like screen and multiply. But you can try others like hard light or anything you like. To adjust the amount/intensity, I generally just play with the opacity of the grain clip.
  • Alex Elkins
    December 20, 2011 at 11:10 am
    This is a bit of a strange way to add grain in my opinion. This should have been done during the grade. Failing that, I’d recommend bringing the entire film into After Effects and adding a grain filter to it.
    It’ll take a very long time to render from After Effects but you’ll have more control and the results will be much better. I would consider the method of overlaying the grain in FCP a bit of a ‘bodge’ as essentially all you’re doing is adding some animated noise onto the image. That’s not really the same as grain.
    Alex Elkins
    Twitter: @postbluetv
    http://www.PostBlue.tv
    View Post Blue showreel
    Shot on RED @ 100fps, Post on FCP/Color: Capoeira Film
    My Vimeo Pro page
  • Andrew Smith
    December 20, 2011 at 1:22 pm
    I already know this.
  • Alex Elkins
    December 20, 2011 at 1:58 pm
    [andrew smith] ” I already know this.”
    So what do you want to know???
    Alex Elkins
    http://www.postblue.tv
    My Vimeo Pro page
  • Andrew Smith
    December 20, 2011 at 2:09 pm
    In DaVinci I can use composite nodes as well to use my AE rendered grain and adjust with contrast accordingly – otherwise grain is not built into Resolve or FCP.
    ultimately I was hoping to take away from this whether or not my AE settings for grain were correct and then my application of it in other apps…
  • Alex Elkins
    December 20, 2011 at 2:34 pm
    [andrew smith] “I was hoping to take away from this whether or not my AE settings for grain were correct and then my application of it in other apps”
    See my previous post. The way you’re adding grain is flawed – you’re not adding grain if all you’re doing is overlaying an animation of some noise on top of your video. If you don’t want to bring the completed video into After Effects to add grain there, I’d suggest simply adding a monochrome ‘Add Noise’ filter to it in FCP. This is essentially what you’re doing anyway by compositing a noise layer on top of the video, only you’ll have more control and slightly better results with the FCP filter.
    Alex Elkins
    My Vimeo Pro page
  • Andrew Smith
    December 20, 2011 at 2:46 pm
    ok so if i add it in AE what advice on settings and how to can you provide as its a long render and I just want to get it right the first time – maybe I’ll just set a 2 minute in/out to try some variations to test.
    Any advice on how best to bring it the footage and apply grain would be awesome since fcp seems to not be the ideal workflow.
    thank you!
  • Alex Elkins
    December 20, 2011 at 3:01 pm
    [andrew smith] “what advice on settings and how to can you provide”
    I’d start with the presets and tweak from there. There’s not a right or wrong way to do it, just whatever works for what you’re trying to achieve.
    If you want some inspiration I’d recommend looking at some music video websites (e.g. https://www.promonews.tv) – music videos can be a great source of inspiration for digital grading as they’re often heavily stylised and more often than not are shot digitally, so many of them have had grain added in post. See what kind of looks might suit your project and try to emulate it.
    Alex Elkins
    My Vimeo Pro page
  • Bret Williams
    December 20, 2011 at 4:57 pm
    Ditto. So the grain is making your footage darker or something. Ok, now add some color correction to brighten it up. Or did you already know that? Is that too obvious for you?
  • Andrew Smith
    December 20, 2011 at 6:41 pm
    thanks chet?
    My point is that my grades from DaVinci were getting affected too heavily and i did not want to have that happen when applying grain…i know there will be some change but i was not happy with what was happening which is why i thought maybe io was doing something wrong.
    thanks
