Activity Forums Boris FX Adding FX as a filter in FCP
  • Adding FX as a filter in FCP
    Posted by Matt Short on June 23, 2006 at 5:51 pm
    When I apply FX to a clip in Final Cut and launch the Boris interface, there is nothing in the timeline. Shouldn’t the clip I applied it to appear? I looked in preferences and the open empty timeline box was unchecked.
    Peter Mcauley replied 20 years, 1 month ago 2 Members · 1 Reply
  • Peter Mcauley
    July 6, 2006 at 9:08 pm
    hello,
    you may have to add the clip to the image well for the filter within the fcp interface – i’ve seen this before in fcp. or you might just want to add a new track in the FX interface (command + K) to see if that does the trick.
    i hope this helps
    peter.
