Activity › Forums › Avid Media Composer › Adding Filler between 2 clips?
  • Adding Filler between 2 clips?
    Posted by Greg Jones on January 30, 2012 at 4:19 pm
    This is probably something easy, but I can’t seem to figure out how to add filler in between two clips in Media Composer 6. I can add filler to the beginning of a sequence, but can’t seem to find a command to pull filler up in the source monitor to insert it into my timeline.
    Greg Jones
    D7,Inc.
    Orlando,FL.
    https://www.d7-inc.com
    Rosie Walunas replied 13 years, 10 months ago 6 Members · 6 Replies
  • Peter Groom
    January 30, 2012 at 4:34 pm
    Is “Load Filler” not in the drop down menu top left of the source monitor
    Peter
    Post Production Dubbing Mixer
  • Greg Jones
    January 30, 2012 at 4:52 pm
    That’s where it is. Thank you. I didn’t look there.
  • Steve Knattress
    January 31, 2012 at 9:24 am
    Just a point that filler cannot be added onto the end of a sequence.
    (eg extend sequence to add an audio punch in or to give a gap before next timeline clip.)
    I just make a black slug (disable “V” to loose transparency) with the title tool and use that.
    Steve
  • Justin Gray
    January 31, 2012 at 10:00 pm
    The title tool trick the Steve mentioned works great. Also, one thing I find incredible handy, is to keep a bin stored on your desktop and cloud that serves as a utility bin. Inside that utility bin I have black slugs, bars/tone sequences, slates and any other “quick grab” stuff I might need. From within any project I can open that utility bin and then I have everything I need.
    Thanks Fellow Bovines,
    Justin Gray
    Senior Editor/Motion Graphics Artist
    Encore Multimedia
    web.me.com/grayplanet
  • Michel Armstrong
    September 20, 2012 at 10:36 am
    Does Filler can disinfect ?
  • Rosie Walunas
    November 12, 2012 at 10:09 pm
    I’m having an issue where the “Load Filler” option is no longer present. How do I fix this?
    Thank you.
