Activity Forums Compression Techniques Adding file info in Compressor
  • Adding file info in Compressor
    Posted by David Modijefsky on November 7, 2006 at 1:05 pm
    Can I add some file info like ‘copyright’ or ‘directed by’, etc? I’ve tried to add some of this data In QuickTime Pro but then the extension is changed to .mov. I want to keep the given extension in this case .mpg. Can this be done or is mpeg not suitable for adding data like this?
    David Modijefsky replied 19 years, 9 months ago 2 Members · 2 Replies
  • Charles Simonson
    November 9, 2006 at 7:06 pm
    An MPEG program stream does not have a metadata layer like QT or Windows Media does.
  • David Modijefsky
    November 10, 2006 at 12:48 am
    Bummer! Thanx Charles.
