Activity Forums VEGAS Pro Adding extra folder to old DVD
  • Adding extra folder to old DVD
    Posted by Paul Gregory on December 25, 2011 at 1:33 am
    I neeed to add a ‘extra folder to a DVD of a wedding that was made many years ago. The video is 40 minutes long & doesn’t even have chapters set. I don’t want to re render file because the quality of the file is attrocious. I know that I can import the old VOB files from the DVD into Vegas & then send it to DVDA where the extra folder can be added.
    Does this invold a re render or not?
    Would adding chapter markers cause a re render?
    Do any other programs allow for the inclusion of extra’s before the DVD is burned, fD
    or example Nero or VideoReDo?
    Thanks in advance
    John Rofrano replied 14 years, 8 months ago 2 Members · 1 Reply
  • John Rofrano
    December 26, 2011 at 1:46 pm
    [Paul Gregory] “Does this invold a re render or not? “
    If you are just adding a folder to the disc, why not just copy the VIDEO_TS and AUDIO_TS folders to a folder on your hard drive, add your new folder with extras, and then burn the entire thing back to DVD without ever touching the video?
    [Paul Gregory] “Would adding chapter markers cause a re render? “
    If you want to add chapters that’s won’t require a re-render. You would have to convert the VOB files back to MPEG-2 and add them back to a DVD Architect project and add the chapters in DVD Architect. It should just reuse the MPEG2 files without rendering.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
