Activity Forums DaVinci Resolve adding external matte from embedded alpha channel
  • adding external matte from embedded alpha channel
    Posted by Sherwin Akbarzadeh on May 3, 2013 at 3:24 am
    Hi guys,
    Just running some tests for a upcoming grade. The test material has been composited and exported as RGB + Alpha. We want to grade the 2 layers separately in Resolve 9 Lite.
    I thought that I would be able to pull an external matte in Resolve from the Alpha channel within the clip. But all of the documentation I have seen including Juan Salvo’s helpful tutorial https://vimeo.com/49029693 uses a separate file to create this external matte.
    Just trying to minimise the number of files/legwork we have to deal with. Is there a way to do it my way ?
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Johnathan Throbins replied 12 years, 1 month ago 3 Members · 4 Replies
  • Juan Salvo
    May 3, 2013 at 4:00 am
    You can use after effects for example to render that alpha as a matte and then use it that way,
    I believe Resolve 9.1 respects alpha channels in prores 4444 files for titles and the like.
    Thanks for the kind words Sherwin, good luck.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Sherwin Akbarzadeh
    May 4, 2013 at 9:36 am
    Thanks for confirming this Juan. All the best.
    May 8, 2013 at 4:25 am
    Hmmm… Just a follow up question:
    How can I control the matte and the inverse matte seperately?
    I have added a serial node and added matte and am able to control the matte layer separately. I would like to be able to do the same for the inverse matte. At the moment my adjustments of node 1 (below) affect the entire image.
    I have tried going back to media and adding the matte layer twice to a clip and then selecting straight for one and inverse for the other but this is not giving me an inverse matte.
  • Johnathan Throbins
    July 31, 2014 at 5:36 am
    you just have to click the invert button on the key input tab
