Activity Forums Adobe After Effects adding expressions to multipul layers
  • adding expressions to multipul layers
    Posted by Razamataz on December 3, 2005 at 3:46 pm
    The problem which I’m having is I need to apply the same expressions to about 300 layers. Does anyone know a quick way of doing this. All the layers are different so I can just dupe one 300 times and I have also tried selecting all the layers and applying the expression to one which didn’t work either.
    Thanks in advanced for your help
    Dan Ebberts replied 20 years, 9 months ago 2 Members · 1 Reply
  • Dan Ebberts
    December 3, 2005 at 4:52 pm
    If you have AE 6.5 you can select the property, then Edit > Copy Expression Only, then select all the other layer and Edit > Paste.
    Dan
