Adding expressions to Mask Shape property’s keyframes (AE7)
using
loopOut(type=”cycle”,numKeyframes=0)
I easily looped the keyframes of a test layer’s opacity.Unfortunately, I want to loop the keyframes of a layer’s Mask Shape. But when I select the property and attempt to use “Add Expression”, it’s greyed out (not available).
This is aggravating, ‘cuz I don’t want to do anything fancy with the shape per se, I just want it to loop.
Is there any way around this in AE7?
Thanks.
“Putting the HARM in ‘harmonica’ since 2005.”
