Activity › Forums › Adobe After Effects › Adding expression to meshwarp
  • Adding expression to meshwarp
    Posted by Geoff Lillemon on September 17, 2006 at 4:54 pm
    hey im just wondering if its possible to attach certain points in a mesh warp to an audio adjustment amplitude layer using expressions, it doesnt give me an add expression ability when i click the mesh warp properties. thanks alot
    -geoff
    Geoff Lillemon replied 20 years ago 3 Members · 3 Replies
  • Dan Ebberts
    September 17, 2006 at 8:05 pm
    Nope, sorry. You can with Bezier Warp though, if that’s any help.
    Dan
  • Mike Clasby
    September 18, 2006 at 5:06 am
    If you just want to bend ro sag a layer, Bender can do some nice Bends and wiggles(4 styles), adjusting Positons and amounts, all open to expressions. Play with the controls and move with expressions. Might work for you. I had bigfoot do a booty shake, hip sway controlled by Audio Amplitude on CC Bender over the hips here:
    https://media.putfile.com/Bender-Curtain
  • Geoff Lillemon
    September 21, 2006 at 4:11 pm
    oh great thanks alot, i ended up using the bezier warp tool.
    which worked well enough to have audio effect the distortion of a horn.
