Activity Forums Adobe After Effects Adding elements to stills to make them more interesting
  • Adding elements to stills to make them more interesting
    Posted by Dave Blair on December 17, 2008 at 12:20 am
    Hi –
    I need to put a kind of glistening or gleaming on stills of water and am wondering the best way to do that. I don’t have many plugin packages, so…
    Also, I have a photo of someone twirling fire, and they want to liven the photo up by adding fire-like elements to this. Any ideas anyone? Also, any other ideas anyone might have to generally liven up stills (besides the obvious of just putting some motion to them)
    Dave
    Edward Collier replied 17 years, 5 months ago 2 Members · 2 Replies
  • Dave Blair
    December 18, 2008 at 8:27 pm
    Your advice is to get moving video? Geez, Thanks.
  • Edward Collier
    April 28, 2009 at 1:40 pm
    for the flame i would recomend particular or layer up the particles that come with.
    the water is a little more complicated. but step by step:
    1) create a layer of fractal noise, set it to swirly and evolve it gently, animate it moving from left to right also gently.
    2) repeat step one but get the noise to move right to left.
    3) change the opacity of the top layer to 50%
    there you have your animated water texture.
    4) precompose, convert to a 3d layer and rotate it to match the plane of the surface of the water in your picture. use it as a displacement map, and also fiddle with the blending mode and opacity to get some sparkles.
    5) add glow if nessicary.
    hope thats more helpful; it wont look photoreal, but it should look interesting.
