Activity Forums Adobe After Effects adding effects to the scence
  • adding effects to the scence
    Posted by Dotan Baytman on July 7, 2005 at 7:29 am
    HI
    i was wondering how do i add the effects on a movie
    lets say i have a video of myself and want to create an effect of throwing a plasma ball or shooting lasers
    i make the plasma ball in 3d max or any 3d software
    then what? how do i put it on the video and make it look like im throwing
    it?
    do i make the ball animate in the 3d package? or in AE
    thanx 4 any help
    Dotan Baytman replied 21 years, 2 months ago 3 Members · 4 Replies
  • Michael
    July 7, 2005 at 1:26 pm
    you could use the AE “beam” effect to make a laser beam…or you could use the lightning effect to cast a bolt of lighting…these can be added to your video without much trouble…you would just have to shoot a video again of you throwing something….then add the effects. To throw a ball, you would have to shoot the ball by itself against a blue screen…then take out the background, and add just the ball to the scene. Another way is to take a digital pic of the ball and use Photoshop to select just the ball, then rotate the ball in AE, etc….the tricky part will be the lighting…
  • Aharon Rabinowitz
    July 7, 2005 at 2:14 pm
    YOu can do a lot in AE without using 3D for an effect like this, but if you like your 3D effect’s look, then here goes:
    It depends – if you want to animate the motion of the ball, you’ll need to bring your BG footage into your 3D program and then match the motion up there.
    Or you could just render the ball stanbding still (but otherwise animating it’s colors and light and rotation).
    Either way, when you are done, render it out with an alpha channel (if you can get a straight alpha as opposed to a premultiplied one, that would be great) and bring it into AE.
    It comes in transparent in the right places, and then you just drop it on top of your footage. If you planned on doing the motion in AE, make sure to turn on the comps motion blur (and the layer’s too) and then just animate the poition of the energy ball.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Aharon Rabinowitz
    forgot to tag this to reply to me
    Aharon Rabinowitz
  • Dotan Baytman
    July 8, 2005 at 9:24 am
    Thanx guys for the replys that helped alot
    just one more thing
    i know shooting lasers i prefer doing in AE
    but if i have effect of a plasma or fire ball that look cool in a 3d program wich way is better to render in? the 3d program or AE?
    p.s aharon what do u mean render as alpha as straigt?
    can i choose what kind of alpha?
    thanx alot guys
