Activity Forums Adobe Photoshop adding effects to multiple files at once (i.e. image sequence from AE)
  • adding effects to multiple files at once (i.e. image sequence from AE)
    Posted by Ej Mcleavey-fisher on October 30, 2005 at 3:41 am
    is there any way to add effects to multiple files at once, or in some way where its not done manually file by file? i’ve done stuff by exporting image sequences from AE then doing each file individually, but its obviously time-consuming, and i’m hoping there’s a better way. any help is great, thanks.
    Richard Harrington replied 20 years, 10 months ago 2 Members · 1 Reply
  • Richard Harrington
    October 30, 2005 at 4:49 am
    Look up actions and the Batch Command
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
