Activity Forums Apple Final Cut Pro Legacy Adding effects to every transition between in and out points
  • Adding effects to every transition between in and out points
    Posted by Wynn Winberg on November 8, 2007 at 3:07 am
    OK, I’ve had a hard time finding this feature – I want to add a dissolve to every cut in my sequence at once. On Avid the choice of “Add In-Out” is on the menu when I add an effect, but I can’t find it on FCP. Can someone set me straight?
    Thanks –
    Wynn Winberg
    Aries Productions
    Wynn Winberg replied 18 years, 10 months ago 2 Members · 2 Replies
  • Paul Escandon
    November 8, 2007 at 3:26 am
    The way you accomplish this isn’t exactly the most obvious – but it will work. First select everything on your timeline. Then drag the entire selection over the canvas window and choose overwrite with transition. It will use whatever transition is set as your default transition. If everything goes right you’ll have cross dissolves at every edit point. There is the possibility of errors happening depending on how your timeline is laid out… and if you have a lot of tracks of video or improper handles on some of the clips you may run into some problems… but go ahead and give it a shot.
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Wynn Winberg
    November 8, 2007 at 3:29 am
    Thanks for the workflow idea, but wow – seems like there would be a less bulky approach to this simple process. I’ll give it a shot though.
    Thank you –
    Wynn Winberg
    Aries Productions
