Activity Forums Adobe After Effects Adding effect like lens flare to ADJUSTMENT LAYER on Video Footage
  • Adding effect like lens flare to ADJUSTMENT LAYER on Video Footage
    Posted by Serg Merci on December 9, 2005 at 9:38 am
    Hi guys,
    I’ve been trying to add effects to a COMP i made from a PAL video footage. All I want to achieve is to be able to make the effect last a certain period of time and then be able to have it stop.
    I read that using an adjustment layer was the way to go.
    But when I have, say, COMP1 and then add an ADJUSTMENT LAYER to that…and then add an effect (eg.lens flare)to the adjustment layer… I CANT SEE IT!
    I only see the lens flare when I put it directly onto the COMP1.
    What am I doing wrong? Can somebody help please?
    Thanks heaps.
    Serg.
    Spritemaster replied 20 years, 8 months ago 3 Members · 4 Replies
  • Mylenium
    December 9, 2005 at 9:50 am
    Adjustment layers have a transparent Alpha and effects that do not calculate Alpha don’t show. In your case don’t use an Adjustment layer. Put your lens flare on a normal black solid and use the add or screen blend mode.
    Mylenium
    [Pour Myl
  • Serg Merci
    December 9, 2005 at 4:39 pm
    I thank you for your invaluable advice Mylenium.
    I will give it a go…as you said…and see how it goes.
    Cheers!
    Serg.
  • Serg Merci
    December 10, 2005 at 7:51 am
    Hi Mylenium,
    Thanks for that advice. I tried it but it didn’t work for me. Am I doing something wrong I wonder?
    I have added a solid black layer and added the effect to that layer and used blend mode ADD and SCREEN but it doesn’t show…
    Any other ideas?
    All I want to do is be able to add lighting to a video footage and be able to control when I can turn it on and off…
    Cheers.
  • Spritemaster
    December 10, 2005 at 9:08 am
    “It doesn’t show” meaning you still see your video but not the flare? When you added the black solid, did you see it? It’s supposed to hide your footage, so I wonder if you haven’t put it underneath by mistake. You can also apply a Render-Lens Flare effect directly to the footage layer.
    Not sure what you’re doing wrong, but frankly this is RTFM stuff 🙂 Or the Calf…
    AA
