Activity Forums Adobe After Effects Expressions Adding digits from Numbers filter
  • Adding digits from Numbers filter
    Posted by Chris Heuer on August 6, 2008 at 4:22 pm
    I’m low on time or I’d surf Dan’s site for this!
    I don’t know if this is possible…
    I have to update the Medal Count every day during the Olympics. The producer wants 3 columns (Gold, Silver, Bronze) and numbers below each that are changing randomly. We reveal the count by having each number lock into place, first Gold then Silver then Bronze. Then a “Total” Medal sum appears in RED.
    I’m using the effect: Effects>Text>Numbers to generate the number info
    Settings:
    “Type”is set to:Number
    “Decimal Places”is set to: 0 and
    “Value/Offset/Random”is set to: whatever Medal count I put in i.e. 435 (random is unchecked).
    I’d love to create an expression that adds the 3 numbers together and automatically applies the sum to my RED “Total” layer. The red layer doesn’t appear until the 3 digits stop animating so if this expression causes the RED number to animate, that’s ok!
    I hope this makes sense. Any pointers would be great.
    Thanks, Chris
    Chris Heuer
    Freefall FX, LLC
    Chris Heuer replied 18 years ago 2 Members · 4 Replies
  • Dan Ebberts
    August 6, 2008 at 4:34 pm
    Unless I’m missing something, the expression for the total will look something like this (assuming all instances of the Numbers effect are applied to the same layer):
    gold = effect(“Numbers”)(“Value/Offset/Random Max”);
    silver = effect(“Numbers 2”)(“Value/Offset/Random Max”);
    bronze = effect(“Numbers 3”)(“Value/Offset/Random Max”);
    gold + silver + bronze
    Dan
  • Chris Heuer
    August 6, 2008 at 5:59 pm
    I was hoping to do it with one 3 digit instance of the numbers effect but after seeing your expression, I see how that probably doesn’t work. I’ll make an instance for each number and your expression should work perfectly!
    Thanks, Chris
    Chris Heuer
    Freefall FX, LLC
  • Dan Ebberts
    August 6, 2008 at 6:13 pm
    If you just want to add up the digit from one Numbers effect, this should work:
    s = Math.round(effect(“Numbers”)(“Value/Offset/Random Max”)).toString();
    total = 0;
    for (i = 0; i < s.length; i++){ total += parseInt(s[i],10); } total Dan
  • Chris Heuer
    August 6, 2008 at 7:03 pm
    I’m going to try that just for the learning. I turns out that the expression you gave me with 3 instances is the perfect solution because the medal counts should go into double digits. 3 double digit instances of the Numbers effect with your expression works perfectly!
    Thanks for the revised expression. I’ll put it to good use.
    Chris
    Chris Heuer
    Freefall FX, LLC
