Activity Forums Adobe After Effects Adding depth to a flat image (3D?)
  • Adding depth to a flat image (3D?)
    Posted by Geoff Roughface on April 2, 2010 at 9:05 pm
    I’ve got a graphic for an event that I want to kind of rotate from side to side using the 3D camera. Doing this is easy and I’ve got that part down, but as you can imagine the the image is flat and it doesn’t look as cool as I want it to. Is there a way in AE or PS that I can had that depth to it so when it rotates the image has some depth?
    THanks guys
    Robert Craghead replied 16 years, 4 months ago 4 Members · 4 Replies
  • Todd Kopriva
    April 3, 2010 at 1:32 am
    Here’s an After Effects Community Help search that brings up several ways. My favorite is the use of the Shatter effect.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Robert Craghead
    April 10, 2010 at 9:09 pm
    Did you add a light in the 3d camera? Also may want to check out zaxworks.
    Robert Craghead
    Founder
    Ten Stories
    2775 Kurtz Street, Suite2/3
    San Diego, CA 92110
    T: 619.295.5650 x101 F: 619.295.4838
    rob@tenstories.com
    http://www.tenstories.com
  • Craig Whitaker
    April 11, 2010 at 12:20 am
    Can you break it up and multiplane it?
  • Robert Craghead
    April 11, 2010 at 1:32 am
    In zaxwerks yes. Check it out very user friendly
