Activity › Forums › Adobe After Effects › adding decay to Dan’s random lines script
Posted by Gary Nicholson on January 11, 2006 at 5:19 amHi Dan
Is there a way to add decay to your Random Line script.
Also a big thanks for your support to After Effects scripting.
Gary
PS Anyone can jump in if they have a solution thanks.
Gary Nicholson replied 20 years, 8 months ago 2 Members · 4 Replies -
Dan Ebberts
January 11, 2006 at 2:18 pmI’m not sure what you mean by decay. Do you want the lines to slow down and stop at random positions, return to their original positions, or something else entirely?
Dan
Gary Nicholson
January 12, 2006 at 12:43 amHi Dan
Slowing the lines down to a stop is the effect I’m after.
Thx
Gary
Dan Ebberts
January 12, 2006 at 4:01 amI was afraid of that. 🙂
Something like this might work:
decayStart = 4; decaySpeed = 4; segMin = .3; //minimum segment duration segMax = .7; //maximum segment duration minVal = 0; maxVal = thisComp.width; end = 0; j = 0; if (time > decayStart){ delta = time - decayStart; factor = 1 + delta*delta*decaySpeed; }else{ factor = 1; } while ( time >= end){ j += 1; seedRandom(j,true); start = end; end += random(segMin,segMax)*factor; } endVal = random(minVal,maxVal); seedRandom(j-1,true); dummy=random(); //this is a throw-away value startVal = random(minVal,maxVal); y = position[1]; ease(time,start,end,[startVal,y],[endVal,y])Dan
Gary Nicholson
January 13, 2006 at 12:36 amHi Dan
Just what I needed, thanks for your help and time.
Gary
