Activity Forums Maxon Cinema 4D adding customised icons
  • adding customised icons
    Posted by Alan Lacey on May 29, 2006 at 6:40 am
    There are many command in C4D that do not have icons associated with them. As these are 32×32 tifs is there a way of adding your own?
    I tried just adding one to one of the plugins folders that doesn’t have one, but no luck.
    Thank you
    Alan
    Alan Lacey replied 20 years, 3 months ago 4 Members · 6 Replies
  • Adam Trachtenberg
    May 29, 2006 at 4:17 pm
    Unfortunately you can’t add custom icons.
  • Mylenium
    May 29, 2006 at 4:32 pm
    [Adam Trachtenberg] “Unfortunately you can’t add custom icons.”
    Not entirely true (no offence). Just read an article that would allow such things to be done using COFFEE scripting. Have to look into the matter, but it seems that scripts are able to add data to the global resource files, thus allowing this behavior.
    Mylenium
    [Pour Myl
  • Alan Lacey
    May 29, 2006 at 4:36 pm
    Oooo! if you do manage to puzzle it out can you give a thicko like me some ‘short word’ guidance please.
    Alan
  • Björn Marl
    May 29, 2006 at 5:32 pm
    Yes, by using a function in a script and assigning the script an icon you can get around this limitation.
    Assigning icons to scripts is very easy, you just hit one button and the current view is rendered as an icon.
    Using the functions is mostly rather easy too, the commandmanger will show you the commands number which you can use with callcommand in the script.
    Cheers
    Bj
  • Adam Trachtenberg
    May 30, 2006 at 5:11 am
    Well there you go–learn something every day. 🙂
    Note to self: must look into this scripting/coffee business.
  • Alan Lacey
    May 30, 2006 at 7:56 pm
    thanks Bjorn
    I must check out this scripting/coffee stuff too. Way back in my 3DS days I scrited in Max and my guess is it’ll be easier in c4d.
    Alan
