Activity › Forums › Apple Final Cut Pro Legacy › Adding columns in FCP bin
  • Adding columns in FCP bin
    Posted by Marc Roussel on June 16, 2008 at 8:54 pm
    Hi All,
    First time forum user. Really need help with this one as I have tried everything I know and couldn’t find anything in the manual, but is there a way to add a new column to a bin and give it it’s own name that isn’t part of the FCP default columns. My editors would like to add specific columns for notes.
    Any help would be appreciated.
    Marc
    Stace Carter replied 18 years, 3 months ago 2 Members · 2 Replies
  • Stace Carter
    June 17, 2008 at 12:56 pm
    My system is tied up on a render but as I recall you have several “User” columns (probably hiding all the way over to the right) which you can at the least re-order, if not rename.
    Cheers,
    S
  • Stace Carter
    June 17, 2008 at 2:05 pm
    edit – here’s a timely tip from Larry Jordan:
    https://www.larryjordan.biz/tips/tip68.html
