Activity Forums VEGAS Pro adding Closed Captions in Vegas 10e for DVD rendering
  • adding Closed Captions in Vegas 10e for DVD rendering
    Posted by Larry Brewer on September 17, 2011 at 6:13 pm
    It’s about time I checked in to see if anyone as figured out the workflow so that I can add Closed Captions on the Vegas timeline and render them to be burned onto a standard def 16 x 9 DVD.
    The first part is easy enough. I can add the captions, and the captions play on the Vegas preview monitor.
    I can export a valid SCC file.
    But no captions appear on my TV when the DVD is burned from this render.
    Where am I going wrong?
    Rob Franks replied 15 years ago 3 Members · 2 Replies
  • John Rofrano
    September 17, 2011 at 9:21 pm
    [Larry Brewer] “But no captions appear on my TV when the DVD is burned from this render.”
    I believe that Line 21 captions are stored in a special location on the DVD disc and are only supported for Region 1 discs and Vegas Pro/DVD Architect does not support this. So you are not doing anything wrong. It just isn’t supported.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rob Franks
    September 18, 2011 at 12:27 pm
    Try doing subtitles. The subtitles work for me.
