Activity Forums Adobe After Effects Adding bounce/elasticity to tracked null object
  • Adding bounce/elasticity to tracked null object
    Posted by Lance Gambis on October 8, 2013 at 6:11 pm
    I have an object (graphic) this is tracking another object using motion tracking. How do I insert some elasticity/bounce/delay between the graphic and the object it is tracking. Not sure if I’m explaining myself correctly. More specifically, I have someone walking and being followed by a dark cloud. But I want to inject a natural/organic movement into how the cloud moves over the person.
    Perhaps I’m not using the right search terms but I could not find
    anything.
    Thanks for any help or for pointing out any tuts that might put me on the right path.
    Tudor “ted” jelescu replied 12 years, 11 months ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    October 8, 2013 at 9:15 pm
    Add the Point Expression Control to the tracked layer. Then add the following Expression to its Position property –
    value+effect("Point Control")("Point")
    You should now be able to manually add keyframes to Point Control, to offset the original tracking data.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Lance Gambis
    October 9, 2013 at 12:16 am
    Thanks for your tips–will put them into action!
    October 9, 2013 at 12:21 am
    Instead of the method I specified in the earlier post, you could also offset the tracked position by keyframing the Anchor Point.
    HTH
    RoRK
  • Tudor “ted” jelescu
    October 9, 2013 at 8:31 am
    For realistic interactions you can test Newton- it can provide you with the natural feel you’re after.
    Tudor “Ted” Jelescu
    Senior VFX Artist
