Activity Forums DaVinci Resolve Adding blur to a moving object in fusion
  • Adding blur to a moving object in fusion
    Posted by Sean Lennon on March 12, 2021 at 8:16 pm
    Hi, I’ve added a tracker to track an object moving through time, I want to blur that object as it moves through time. My node pipe is ‘media in – Tracker – blur – media out’, I also have a text node merged with the tracker and blur. My issue is that I can’t seem to blur just the tracked object, instead the whole image is blurred. Anybody have any tips here or any idea of what i’m missing here?
    S
    Glenn Sakatch replied 5 years, 5 months ago 3 Members · 4 Replies
  • Yoav Dagan
    March 12, 2021 at 9:37 pm
    Hi Sean,
    You will need to add a mask to the blur to define the blur area, than you will add the mask’s position to the tracker data (Track1 etc’)
    Good luck
  • Sean Lennon
    March 14, 2021 at 12:23 pm
    Thank you!
  • Sean Lennon
    March 14, 2021 at 12:40 pm
    One other question, I have put text on top of the blurred area, but the blur is layered over the text area in some parts, this must be an issue with my node piping?
  • Glenn Sakatch
    March 21, 2021 at 5:57 pm
    Anything you don’t want blurred simply has to be farther down your nide tree than your blur…its just like working in layers
