Activity Forums Adobe After Effects adding blur text animation preset movement?
  • adding blur text animation preset movement?
    Posted by Paul Dougherty on November 19, 2014 at 4:41 pm
    It’s easy to add motion blur on titles moved using the regular position parameter but when the movement comes from a text animation preset, it doesn’t seem to work. Is this the nature of the animal?
    Paul
    Paul Dougherty replied 11 years, 10 months ago 2 Members · 4 Replies
  • John Cuevas
    November 19, 2014 at 5:48 pm
    Which preset(s) are you using?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Paul Dougherty
    November 19, 2014 at 6:37 pm
    Actually they are ones I improvised using the Animate parameters in Text (so I should have not called it a preset). I’m doing a slide on that involves Animate position keyframes as opposed to layer position keyframes.
    Paul
  • John Cuevas
    November 19, 2014 at 7:32 pm
    Post a screen grab of your timeline, with the text parameters open, because you can absolutely add motion blur to text, that is animating via text animators.
    Thinkck.com
  • Paul Dougherty
    November 19, 2014 at 7:47 pm
    My Bad – I mixed ip the column header for motion blur with the Master on/off switch above it
