Activity Forums Adobe After Effects Adding blood in post
  • Adding blood in post
    Posted by Calum Macphail on May 1, 2010 at 7:13 pm
    I’m looking for a way to add blood to an actors face in post (i didn’t have time when originally shooting). I’m a relative novice with after effects so i thought i would turn to you guys. I’m a mac user and my editing system is Final Cut Pro.
    Calum
    Calum Macphail replied 16 years, 4 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    May 1, 2010 at 10:30 pm
    First thing to do is to track the face- if there’s no 3d movement, or very little of it, Mocha should do it. If not, use Syntheyes or Boujou.
    Then paint out blood on the face on a relevant frame in Photoshop, animate if necessary and apply track data to layer. Final step is to apply color correction to make it blend in.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Simon Bonner
    May 2, 2010 at 12:01 am
    You might find this tutorial useful: https://videocopilot.net/tutorials/the_healer/
    This method won’t work miracles, so if you need to show your actor at various angles etc, you’ll probably save time by reshooting.
    Simon Bonner
    youtube.com/simonsaysfx
  • Calum Macphail
    May 2, 2010 at 1:12 am
    Thanks for your response. The only reason i thought i would ask is because the actor was stationary, therefor i thought it may well be easily achievable
