Activity › Forums › Apple Motion › Adding Bezier Points to animated mask?
  • Adding Bezier Points to animated mask?
    Posted by Ludwig-design on November 29, 2006 at 7:14 pm
    Hello,
    Is it not possible in Motion to add or remove points during a vector animated mask (that changes shapes)?
    If not, any suggestions of a workaround? I need to make this big curley-q shape build in following the shape of the curley-q… so it starts out simple and gets real hairy. It would be great if I could add points as it goes, but that doesn’t seem to work?
    Jim Kanter replied 19 years, 10 months ago 2 Members · 1 Reply
  • Jim Kanter
    December 5, 2006 at 1:36 am
    A mask has to have a number of fixed vertices — you can’t add or remove any during an animation. If you need 20 points to define the most complex shape, those same 20 points must also define the most simple shape.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
