Activity Forums Apple Final Cut Pro Legacy Adding audio to timeline, after adding just video
  • Adding audio to timeline, after adding just video
    Posted by Paul Ray on November 19, 2010 at 7:35 pm
    Hello,
    Here is my situation; I dropped a bunch of video clips into my timeline WITHOUT the corresponding audio, thinking I didn’t want any nat sounds….
    Looking at it now, I want those nat sounds, and am wondering if there is a short cut to dropping the audio into the timeline with the corresponding video without having to pull each clip again from the viewer.
    Is this possible?
    Thanks for any help,
    Paul
    Paul Ray replied 15 years, 9 months ago 4 Members · 5 Replies
  • Joe Severino
    November 20, 2010 at 7:16 am
    did you use the in and out points in the canvas before dropping them to the timeline or did you drop the full clip to the timeline and edit on the timeline?
    Mac Pro 3.2 GHz Dual Quad Core
    14GB RAM
    NVIDIA 8800 GT
    Blackmagic Intensity Pro
    OS X 10.6.3 (Clean Instal)
    Final Cut Studio 3 (Clean Instal)
    Logic Studio (Clean Instal)
  • Dan Monro
    November 21, 2010 at 10:28 pm
    I don’t know of any automatic way. If I had to do it, I’d use the track selector to select only the video track, but patch audio, then do the following for every clip:
    mark clip (x)
    go to in (shift i)
    match frame (f)
    mark in (i)
    overwrite (F10)
    next clip (arrow up)
    A pain? Sure. But you’ll never forget your audio again. Not everything can be automatic, not even in FCP. Maybe there is an automatic way – be a whole lot cooler if (there was).
    Good luck,
    D
    Dan Monro
    FCP, Avid, AfterFX, Atlanta
    MacBook Pro 2.53 GHz Intel Core i5 4 GB ram
    Mac OS X 10.6.4
    NVIDIA GeForce GT 330M
    Final Cut Pro 7 Quicktime 7.6.6
    – OR –
    2 x 3.2 Quad Xeon; 16 GB ram
    Mac OS X 10.6.4
    NVIDIA Quadro FX 5600 Final Cut Pro 7.0.2 Quicktime 7.6.6
  • Miriam Lefkowitz
    November 22, 2010 at 5:48 pm
    Instead of doing it the proper way with match frame, I set an approximate in/out in the viewer and pull the audio clip into the timeline, right click and move into sync. Then I drag the audio ends to match the video clip.
  • Paul Ray
    November 23, 2010 at 10:52 pm
    I used in and out points….
  • Paul Ray
    November 23, 2010 at 11:10 pm
    Hey, it works! And that wasn’t half as difficult as learning how to make the F10 button work on this keyboard!
    Thanks for your help,
    Paul
